Note20 Ultra 5G camera edge lighting
(Topic created: 07-20-2021 10:29 PM)
BarnabasCollins
Note20
Looking for help to turn on the camera edge lighting. I saw a YouTube video about my phone that showed a graphic of the edge lighting around the camera bump, similar to the edge lighting around the display screen when the phone rings or during notifications, but no instructions how to turn it on. I've checked the manual and called Samsung Support but no luck on either front. I got 3rd party tech support to assist me with accessing the display edge lighting when Samsung support couldn't find the setting. Would appreciate the help.
LongHiker
Legendary Samsung Care Ambassador
Note20
@BarnabasCollins if you look in Settings -> Notifications -> Brief pop-up settings -> Edge lighting style, you will see the choices available. The one that does something like what you are asking for is "Eclipse".
ValleyRealtor
Note20
Download Goodlock from the Galaxy Store. Family - > Edge lighting+
LongHiker
Note20
