xogeniusnerdxo
- Mute
ā04-29-2021 06:59 PM in
Note20Does anyone have any tips, tricks to taking better photos on Samsung Note 20? Also any ways to save photos online ( Apps ,etc) Thanks
Solved! Go to Solution.
TheVampireRove
Comet
- Mute
ā04-29-2021 08:28 PM in
Note20
You could always use Pro Mode to really dial in your Settings. There's also an option in the settings for Shot Suggestions. This will suggest things you can do to get a better shot according to the AI. Samsung is now partnered up with Microsoft and offer OneDrive storage. In your in the camera app and gallery app, you can enable cloud back up for saved photos and even entire albums.
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "ā Accept as Solution" button by pressing the three dots on the comment.
1 Reply
TheVampireRove
Comet
- Mute
Note20
