- Mute
- Email to a Friend
10-30-2017 08:55 AM in
Note8Solved! Go to Solution.
- Mute
- Email to a Friend
07-09-2018 05:51 AM in
Note8This is what fixed mine:
Go to Settings > Notifications > Advanced
Tap on the 3 dots in the upper right to show system apps.
Scroll down the list and tap 'Phone'
Turn on 'Do Not Disturb Custom Exception'
- Mute
- Email to a Friend
10-30-2017 03:16 PM in
Note8That doesn't sound right, @userkKfvSwKzrK. Has your phone always done this or was this after a software or setting change?
- Mute
- Email to a Friend
10-30-2017 09:44 PM in
Note8- Mark as New
- Mute
- Email to a Friend
11-03-2017 12:42 PM in
Note8Hmm. Did you have any apps installed at all on the phone from the Google Play store? I know some also already come pre-installed on some models like Facebook and Amazon apps.
I want to test your phone with only the Samsung stock applications running. Are you familiar with Safe Mode? If so, please test your phone's call capability in the mode to see if the screen will show the call when locked then. If you're not familiar with Safe Mode on the Galaxy Note 8, here are instructions on how to get into that mode:
- Turn the device off.
- Press and hold the Power key past the model name screen.
- When "SAMSUNG" appears on the screen, release the Power key.
- Immediately after releasing the Power key, press and hold the Volume down key.
- Continue to hold the Volume down key until the device finishes restarting.
- Safe mode will display in the bottom left corner of the screen.
- Release the Volume down key when you see Safe Mode.
Before continuing, please note that when you exit Safe Mode, some of your customization options (Wallpapers, Themes, Etc.) may be reset to default.
Let us know if you still experience the problem.
- Mute
- Email to a Friend
11-11-2017 12:34 AM in
Note8I'm having the same problem with my phone. I tried to start in safe mode which did not work... any other ideas?
- Mute
- Email to a Friend
11-14-2017 01:33 PM in
Note8Hey Community! Anyone else seeing this problem? Anyone have a workaround? Let us know! :)
- Mute
- Email to a Friend
03-11-2018 04:09 PM in
Note8Same issue here
- Mute
- Email to a Friend
03-12-2018 09:30 PM in
Note8Having the same issue, it seem to be after the last update. At least that is when mine started doing it.
- Mute
- Email to a Friend
11-29-2019 08:45 PM in
Note8Same here. I too, am having an issue. Started after last update, and factory reset did not fix it. Still not receiving a notification when receiving incoming call.
- Mute
- Email to a Friend
03-18-2018 01:52 PM in
Note8same thing happening to my phone. I have tried everything! Very frustrating!
