I need help with finding a certain setting.
(Topic created: 01-05-2025 11:32 AM)
TinknMcDiver
Tablets
So i wanted to turn on the setting where if you lift your tablet cover it'll turn the screen on and when you close it, it'll turn off. I looked it up and searched for it all throughout the settings on my tablet and I can't find it at all.
Edit: It was in Accessories🤦‍
TinknMcDiver
Tablets
I finally found it. It was in Accessories
ExtraSauce70
Cosmic Ray
Tablets
I seen a feature called Lift to Wake, which should be under tablet display settings
TinknMcDiver
Tablets
I don't have that setting
TinknMcDiver
Tablets
ExtraSauce70
Cosmic Ray
Tablets
Cool
justgin
Tablets
Lift to wake in settings
mermaidcaviar
Supernova
Tablets
Is it in battery saving options the choices?
TinknMcDiver
Tablets
You go to Advanced features and look for Accessories, then you turn on auto screen on and off.
freddyj19
Tablets
Is it possible that all tablets don't have this feature?  I've looked and looked on my tablet (Galaxy Tab A7 Lite) and can't find it.  My old tablet had it.  Kinda dumb to take that feature away.
TinknMcDiver
Tablets
It's definitely possible. I've noticed features get taken away and put back on many devices. My tablet is the Galaxy Tab S8+
