Galaxy Book 3 Pro 360 doesn't power up with lid after BIOS update
(Topic created: 04-05-2024 11:18 AM)
Jimmy_W
Computers
I have enabled "startup when  lid is opened" in Samsung settings. However, this feature no longer works after a recent BIOS update that Samsung pushed out. Has anyone experienced this or can suggest a fix?
Samsung_Moderator
Computers
Hello! Thank you for reaching out! I would recommend trying the following. First, go into the settings and turn this feature off. After that power down the laptop completely by using the shutdown option in the Windows menu. Then turn the laptop back on and enable the feature again. Then shut down the laptop again. Then power on the laptop again to see if this issue still occurs.
Also, please note that depending on the model this feature will work differently as in most cases the laptop is asleep and not shut down this feature will work.
RockOn1
Computers
Yes. I have had the same issue.
Did you find out how to resolve.
Jimmy-W
Computers
No. I was on the phone with a Samsun tech for 45 minutes and nothing was resolved.  He's going to "report" the issue.
Jimmy_W
Computers
...also, there is no related power setting in the UEFI.
Samsung_Moderator
Computers
Jimmy-2w
Computers
This seems to have fixed the issue. Thanks!
Samsung_Moderator
Computers
That's great to hear!
