- Mute
01-04-2026
07:52 AM
(Last edited
03-27-2026
08:44 AM
by
SamsungAdam
) in
My Galaxy Note 20 Ultra 5G battery is just shutting down even at 64%. Can the battery be replaced for this phone, and how do I get a Samsung approved repair location in Baltimore County, Maryland. Thanks
Solved! Go to Solution.
- Mute
01-04-2026 09:21 AM in
Galaxy Note Phoneshttps://www.samsung.com/us/support/service/locations/
- Mute
01-04-2026 08:20 AM (Last edited 01-04-2026 08:20 AM ) in
Galaxy Note Phones- Mark as New
- Mute
- Mute
05-04-2026 01:37 AM in
Galaxy Note PhonesShutting down at 60%+ is usually a sign the battery is worn out or not holding voltage properly anymore. The percentage looks fine, but under load it drops and the phone powers off. A battery replacement should fix it.
- Mute
05-04-2026 01:41 AM in
Galaxy Note PhonesI’ve seen this happen on a few devices usually the battery starts to degrade and the percentage reading becomes unreliable. So even though it shows 60%, the actual charge can drop suddenly and cause a shutdown. In most cases, replacing the battery ends up fixing it.
