Bluetooth won't play any sound after update
(Topic created: 01-23-2022 09:39 PM)
useryomV5UNB80
Samsung Apps and Services
After you most recent update Bluetooth will connect but will not play sound.
Not applicable
Settings
Apps
Show system app
Search for Bluetooth
Clear data of all related app
Not applicable
Settings
Apps
Show system app
imavinashgautam
Cosmic Ray
Is there any permanent solution? Post Android 12, this short-term fix is becoming recurring for any issue?
useryomV5UNB80
Absolutely Amazing 👏 Thanks Galaxy 😊 Everything Working PERFECTLY 🥰
