Edge panel gone - Edit: Solution Found!
(Topic created: 02-07-2023 06:21 AM)
Cazooie
Galaxy S21
It's turned on in my settings but has disappeared from my phone. Anyone know how I can get it back?
d_spi
Supernova
Galaxy S21
Good morning @Cazooie, I hope you're doing well.
Here's a trick to adjust how you can see your edge panel more for when you need it.
First Open your settings menu by swiping down your notification shade and clicking the gear icon on the top right> next scroll and tap of "display"> then you'll want to scroll and tap on "edge panel"> Last tap on "panel" from here is where you can not only make sure it's on but you can also adjust how transparent, how thick you want the edge panel border so it's easier for you to notice when you need access to it. You can also lock its position in this little sub menu.
I hope this helps.
_Sara_
Galaxy
Galaxy S21
Restart the device
Cazooie
Galaxy S21
I did and still missing 😭
IRStaten
Nebula
Galaxy S21
U can't swipe the sides ?
d_spi
Supernova
Galaxy S21
I hope this helps.
Cazooie
Galaxy S21
Yes! Somehow it was set to 100% transparent. Thank you so much!
d_spi
Supernova
Galaxy S21
You're very welcome. Have a great day! 👍🏾
