- Mute
02-24-2022
07:29 AM
(Last edited
08-02-2022
05:31 PM
by
SamsungCaleb
) in
Where can I find a list of tv models that offer multi audio output. I need to be able to connect bluetooth headphones and use those AT THE SAME time as the TV speakers. I do not see this feature listed on spec sheets.
Can someone confirm this feature for the TV below?
SAMSUNG 65 Class TU700D-SEries Crystal Ultra HD 4k SMart TV UN65TU700DFXZA
Solved! Go to Solution.
- Mute
02-25-2022 10:33 AM in
Home TheaterGood afternoon, I will be happy to assist you. You can enable Multi Output Audio on this model from Settings - General Accessibility - Multi-output Audio. This feature will only work if you do not have a soundbar or home theater system connected. If it appears to be greyed out in the menu, please exit the Smart Hub to allow access to the setting. You can find more information in the User Guide at the following link. User Guide Link
- Mute
02-24-2022 08:56 AM in
Home Theater- Mark as New
- Mute
