- Mute
05-30-2024 12:56 PM in
KitchenI just got this refrigerator on Sunday. At first it wasn't making ice at all, so I reset the icemaker and started getting a handful of ice cubes a day. Today, only 2 cubes have been produced. Any idea if a service call is needed or how to rectify the issue? Thanks.
Solved! Go to Solution.
- Mute
12:43 PM
(Last edited
05-31-2024
12:44 PM
by
SamsungStephani
Hello there, and thank you for reaching out to our Samsung Community regarding the ice production. The important thing to remember is the ice maker typically makes 1 tray of ice every 90 minutes. However, to assist you with the ice production you can try some of these steps below:
- Lower the freezer temperature. The freezer temperature must be 0 °C (32 degrees Fahrenheit) for the ice maker to work properly.
- Check the water supply line and ensure the water valve on the refrigerator water supply line is completely open.
- Inspect the freezer and verify your freezer is not overfilled.
- Make sure the doors to the freezer are completely closed/closing properly.
- Verify ice maker is turned on (if applicable)
- Reset the ice maker if needed by using this resources link- https://www.samsung.com/us/support/troubleshooting/TSG01207806/#reset-ice-maker-bottom-freezer
Finally, if the issue is still persistent, I would love to assist you further, if possible and you can use any contact method listed below to proceed with that aspect:
Facebook- https://www.facebook.com/samsungsupport/
Twitter- https://twitter.com/SamsungSupport/
Instagram- https://www.instagram.com/samsungsupport/
or
Private Message by selecting any moderator and clicking on the chat option with your full model and serial number
- Mute
05-30-2024 02:46 PM (Last edited 05-30-2024 02:46 PM ) in
KitchenTo me it sounds like a water flow issue and I would suggest contacting support
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
- Mute
12:43 PM
(Last edited
05-31-2024
12:44 PM
by
SamsungStephani
or
