Please help - Fridge: RR14T7414AP - Replacement Shelf
(Topic created: Tuesday)
IntStep555
Kitchen
Hello,
I am at my wits end!
I have a Samsung fridge - RR14T7414AP. Recently my bottom door shelf broke and I've been looking for a replacement part and cannot seem to order one anywhere!
Every type of door shelf that I've seen seems to fit other types of fridges. Either the length is too wide or too short.
I measured the door shelf and it's about 18inches in length and I cannot find a replacemetn anywhere.
Can anyone help me, or at least point me in the right direction as to where I can order this replacement part.
I can't believe that it's this hard just to replace a simple door shelf....
IntStep555
Kitchen
Yeah I've ordered from there already. Ordered twice actually and both were duds.
Again, my fridge seems to be a "Bespoke" model that has a door bin that measures 18 inches in length. I can't find one like this anywhere and it's driving me insane.
innergray
Nebula
Kitchen
might sound crazy, but i'd just contact samsung themselves to see if they have any or could direct me to a place that sells them. i unfortunately have no clue.
AAbbott
Cosmic Ray
Kitchen
Have you tried Samsungparts.com? Does your manual not have a parts list?
Samsung_Moderator
Kitchen
Hello, Intstep555! I completely understand your frustrationโ€”finding the right fit for specific door bins can be tricky.
I agree with AAbbott's suggestion to visit SamsungParts.com. They carry official, genuine replacements that will match the 18-inch dimensions of your RR14T7414AP exactly.
To ensure you get the right part for your specific model, I recommend calling their specialists directly:
> Samsung Parts #: 1-800-627-4368
> Hours: Monโ€“Fri, 9:00 AM โ€“ 6:30 PM EST
Be sure to click " โœ“ Accept as Solution" when you find an answer that works for you.
