- Mute
02-15-2025 07:30 PM in
LED and OLED TVsThe equalizer is all greyed out. I can change the subwoofer but nothing else.
Solved! Go to Solution.
- Mute
03-05-2025 09:45 AM in
LED and OLED TVsHello! Thank you for reaching out! Can you please check if you are using standard sound mode, you can do that by going to Settings → Sound → Sound Mode → Standard. Also please make sure that intelligent mode is turned off, by going to Settings → General → Intelligent Mode Settings. Also please note that you may not be able to control the equalizer settings depending on what audio type is being played. Please turn on PCM to see if this is still occurring. Settings → Sound → Expert Settings → Digital Output Audio Format → PCM. If none of this helps, then it may be a compatibility issue.
- Mute
02-18-2025 12:51 PM in
LED and OLED TVsSame with my TV.
- Mute
03-04-2025 10:17 AM in
LED and OLED TVsOn 03.03.2025 Samsung Support informed me that the Equalizer function is not available on the S95D TV.
- Mute
