Cannot disable Accessibility > Voice Guide
(Topic created: 01-07-2025 02:03 PM)
BThomasson
LED and OLED TVs
The TV has begun to speak the screen as if in Accessibility Mode, even with Voice Guide switched off.  Tried returning to factory settings but no improvement.  Similar problems have been discussed on this board, but apparently they are closed as fixed with no real fix offered.  One previous complaint said their problem was related to closed captioning, but that is not the case with my problem.  It will read the whole program guide aloud.  Firmware is up to date.  It does not seem to affect my Apple TV input, but is limited to my cable box.
TV:  UN60DU7200-XZA.     Less than one year old
BThomasson
LED and OLED TVs
SOLVED.  The problem turned out to be the set-top box from my tv provider.
1 Reply
BThomasson
LED and OLED TVs
