Help configuring TV to automatically turn on to YouTube TV
(Topic created: 06-15-2024 06:13 PM)
Members_Hz1Ueei
LED and OLED TVs
Samsung TV Model UN32N5300AF
Would someone PLEASE provide the exact numbered shortest remote setup steps to configure this TV so that it automatically goes to YouTube TV when the power is turned on?  The Youtube home menu showing the option to select a live program should appear when the power is turned on.
This is for an elderly woman who has no technical abilities and is furious that I changed from Cable to streaming for my TV service.
Thank you.
jcmainman@gmail.com
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
You can try this
Tv settings
General
Smart features
Auto run last app
If youtube was the app when the tv was turned off it should start when powered on
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
1 Reply
GaryB82
LED and OLED TVs
You can try this
Tv settings
General
Smart features
Auto run last app
