Keyboard workaround.
(Topic created: a month ago)
Dawggtired
LED and OLED TVs
I have inherited a Samsung TV from my aunt. All I have is the TV and the remote.
When I turned the TV on, I get a screen saying that it wants to pair with the keyboard. I presuming thatโ€™s a YouTube keyboard, but I donโ€™t have one.
Is there any way to get around this? I want to use the on screen keyboard so I can connect it to the Wi-Fi.
Iโ€™m thinking that somebody has already had this experience and also a workaround.
Malia92D
Cosmic Ray
LED and OLED TVs
If there isn't anything plugged into it, like a USB. Maybe changing the Bluetooth settings could help if it allows you to get there.
Diaboyos
Honored Contributor
LED and OLED TVs
Yes, you can skip the keyboard pairing screen and use the TVโ€™s on-screen keyboard with just the remote.Quick steps:Skip pairing: On the keyboard pairing screen, look for and select โ€œSkipโ€, โ€œCancelโ€, or โ€œUse on-screen keyboardโ€ (use arrow buttons + Enter on remote). If no option shows, press the Back/Return button on the remote repeatedly.
Reset remote pairing (helps most cases):Point remote at TV.
Hold Back (Return) + Play/Pause buttons together for 5โ€“10 seconds until pairing message appears.
Then try Wi-Fi setup again.
Cold boot TV:Unplug TV from wall for 60โ€“90 seconds.
Plug in, turn on, and proceed to Wi-Fi. On-screen keyboard should appear when you select a network and need to enter password. Navigate with arrow keys + Enter.
If stuck: During setup, when highlighting Wi-Fi, press Select/Enterโ€”on-screen keyboard usually pops up automatically. Type password using remote D-pad.
This works on most inherited Samsung TVs. Once on Wi-Fi, you can finish setup normally.
