Samsung  55" TV TU55CU6905K missing "Turn ON" timer in menu, but "Turn OFF" timer exist!
(Topic created: 02-08-2025 01:52 PM)
PerSvensson
LED and OLED TVs
Hi
I bought an mid-range, nothing fancy, plasma Samsung TV about 20 years ago that I can turn on and off the TV by timer unattended.
On my brand new Samsung  55" TV 4K LED Smart-TV,  TU55CU6905K I noticed that there is no turn TV "ON"  timer setting under the menu for time. Strangely there is one timer setting to turn "OFF"!
Seems that there is a logical requirement missing in the software, or bug, to only be able to timer "off" but no "on"? I guess if it was possible on a 20 year old Samsung TV, it should be possible on a new too?
How will the TV be able turn on unattended , if there are no schedule/timer setting for that functionallity?
I'm curious, why would you want a OFF setting but not an ON setting of anything, really? Its a bit like have a turn OFF setting on a car, but not have a setting which turns it ON?
The time is set to auto, and shows correct time.
It gets even more confusing looking at the swedish manual for TU55CU6905K  where it says on page 155 that there is a turn on timer setting under the time menu.
Whereas in the English manual the OFF timer is found in page 85, but not the ON , so only the turn off timer?
The more i read these manuals, and compare the menus in the TV, the less I understand how to use the product.
I have now even updated to the latest firmware in the TV, and still the TV turn ON timer do not show, in the time menu.
Swedish
https://downloadcenter.samsung.com/content/UM/202404/20240426190921443/BN81-24055C-460_EM_OSPDVBEUC_...
English
https://downloadcenter.samsung.com/content/UM/202404/20240424193908343/KT2DVBEUT-2.4.0_EM_KANT_EU_EN...
Will there be any firmware bug fix released for this missing ON timer?
Thanks for any workaround or ideas,
Per
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! Unfortunately, this is not a feature on our TVs. As for any future plans, I can not speculate.
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
Sorry to say but I've never seen a tv with the ability to turn itself on.  I've only seen the sleep timer and the auto off on TV's never a On option for this
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
PerSvensson
LED and OLED TVs
If you have seen that before, you have not seen much in your life.
meself
Honored Contributor
LED and OLED TVs
I know the setting your talking about from older TV sine years ago I got as for your model I'm not familiar with it exactly but would think be in same setting area off top my head timer in clock setting may have to go thru each option on side on settings menu than timer
GaryB82
LED and OLED TVs
@meself  TV's now only have Sleep timers and Off Timers in 20+ years I can't remember a setting that auto turns on a TV
this is what google says but ive never seen it
How to use the On Timer
  1. Press the Menu button on the TV remote
  2. Select System
  3. Select Time
  4. Select On Timer
  5. Configure the timer
meself
Honored Contributor
LED and OLED TVs
Google lied lol been awhile since I used it might be 20 years ago not sure
GaryB82
LED and OLED TVs
Yeah it says they are a setting but in my many years with a Samsung TV I've never seen it just checked the 3 models I have and nothing on them
  2. Select System
  3. Select Time
  4. Select On Timer
meself
Honored Contributor
LED and OLED TVs
Not looked at mine just recalled seeing it on old set
GaryB82
LED and OLED TVs
Yeah my 3 models only say under clock is
Time
  • Clock
  • Sleep Timer
  • Off Timer
thats all 3 of mine
meself
Honored Contributor
LED and OLED TVs
Yes just checked got same wonder why they stopped that option course been years for me seeing it or even looked for it
