Sleep Timer on remote
(Topic created: 05-28-2025 09:09 AM)
HuskerRich
LED and OLED TVs
is wrong sith Samsung not including a Sleep Timer button on the new remotes?  Its 2025, people use the Sleep Timer alot.  And good luck finding it in settings.  You need to take 3 planes, 2 buses and a pack mule to get to the sleep timer setting manually.  Samsung, smarten up and listen to customers, the sleep timer shouldnt be a hidden option, it should be an easily accessed function, RIGHT FROM THE REMOTE!
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! The sleep timer function is not available as a shortcut on the remote or as a dedicate button. You can follow the community advice for the workaround to create a routine. As I don't use the sleep function either, there could be a 3rd party universal remote that could potentially have this dedicated button and work, but I can only speculate on this.
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
As far as I can remember they have never been a Sleep timer button on the Samsung Remotes or any other TV remotes I've owned in the past and I've owned quite a lot of TV remotes over the years and on all of brands you have to go into setting to enable the sleep timer.
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
realaud
Honored Contributor
LED and OLED TVs
People use the sleep timer?  I never had a television of any brand that had a sleep timer button on the remote.  It was always in the settings.  On some TVs, the setting is easier to find than others.  Although, I agree, it would make sense to add it  Why not just create a Smart Things routine if the TV is connected to Smart Things? Or plug the TV into a smart plug and add a timer in the plug's app to turn it off at a certain time.  I think if you have an Alexa device, you can even use Alexa to turn it off at a certain time.
Please mark any response that helped you as your solution.
GaryB82
LED and OLED TVs
Agreed in 40+ years I've never used the sleep timer
realaud
Honored Contributor
LED and OLED TVs
The OP has a smart TV, they can create a routine for that.
Samsung_Moderator
LED and OLED TVs
