Smart Hub issues, can't access apps
(Topic created: 12-01-2024 11:50 AM)
sspahos8
LED and OLED TVs
I cannot get through to Samsung support at any phone number I've tried. It hangs up on me after 30 minutes. The option for support through text is a bot and is of no help whatsoever. Our new LED TV will not access Amazon Prime, Netflix or any app. It says "Smart Hub is loading. Please try again later." Error message  when we use the  troubleshoot option, Smart Hub, says no connectivity with this message: mime-version: 1.0content-type: text/plain; charset=utf-8 content-transfer-encoding:8bit.  I need help before we shove it back in the box and return it to Costco. Not happy.
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! For this, I would recommend reaching out to our SmartThings community using the following link: https://community.smartthings.com/
meself
Honored Contributor
LED and OLED TVs
Just my guess seems a connection issue
sspahos8
LED and OLED TVs
We got so frustrated, trying ALL WEEKEND to get through to Samsung's support teams. Still haven't gotten any help. Now we get followup from a chatbot asking if it is resolved???
Samsung_Moderator
LED and OLED TVs
