TV sparked and stopped working
(Topic created: 02-03-2025 07:11 PM)
DisneyAdult
LED and OLED TVs
  • I was watching TV when my it suddenly turned off, made a loud popping noise, and then sparks flew down from the right side of the TV. Luckily, I was right there to move flammable items away and unplug it from my surge protector. No other items that were plugged into the surge protector has issues. Unsure what to do at this point. I bought this unit back in 2020, a 50” Class 7 series led 4K uhd smart tizen. Please advise.
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! Please call 1 (800) 726-7864 to get this looked into as soon as possible to resolve this. You will need your full model and serial number also. Please do not leave the TV plugged in and unplug it if you haven't done so already.
meself
Honored Contributor
LED and OLED TVs
My guess bad circuits or failing components o would get checked and repaired
Dan2023
Honored Contributor
LED and OLED TVs
These days, like microwave ovens, toasters, and DVD players, though more expensive to purchase, TVs are considered a disposable item and they're often cheaper to replace than repair.
Samsung_Moderator
LED and OLED TVs
