System ui memory leak Android 12
(Topic created: 01-26-2023 02:28 PM)
userEtk4Xb8W4g
Legacy S Phones
Hello guys,
My systemui is memory leaking every couple of days think after some usage of snapchat but i  not quite sure if uts related to CameraX api
Here is some diagnosis
The memoryleak seems to occur in EGL mtrack which means the graphics layers saved? I would like to have assistance from a developer to get into depth
Samsung_Moderator
Legacy S Phones
Hello, Welcome to the Community, and thank you for reaching out! We understand your concern with memory leakage.
We recommend submitting an error report from your phone so that the engineers would be able to take a look. To submit an error report, you can follow the steps here: https://www.samsung.com/ae/support/mobile-devices/how-to-send-error-report-in-your-galaxy-device/
1 Reply
Samsung_Moderator
Legacy S Phones
