C49hg90dm power-up glitch
(Topic created: 01-06-2019 09:00 AM)
usertwgLDE7Itl
Cosmic Ray
Monitors and Memory
Hello,
I've a weird bug with my C49hg90dm. Sometimes when I turn on the monitor I've a glitched black screen followed by a strange cyan-blue screen stranded by lines.
I noticed that the monitor's menu still work in this state but doesn't appear because I can still turn off the monitor normally by pressing the main button, go down and pressing it again. Then when I turn on the monitor again everything works normally. It also work fine if the source change I think because the glitch desappear if I reboot the computer.
I don't know if this issue appear randomly or after a fixed number of power-up. I've also noticed that the image seems slightly different when the monitor is about to glitch on the next power-up.
I don't know if my description is clear ? It's not really annoying but I just hope that doesn't damage the monitor over time.
My monitor is plugged on a surge protector Eaton ellipse eco 650 and with a displayport.
JUMP TO SOLUTION
dcasa
Cosmic Ray
Monitors and Memory
Update: fix here
@SamsungSteph
I appreciate your suggestion but considering that the exact same issue has affected five different units (including one replacement) across three countries (USA, Canada and France) and that all were purchased within the last two months, wouldn't this warrant escalating these reports to a global support team to raise awareness about what is possibly a manufacturing defect affecting all units from a recent production batch and hopefully determine if this is fixable via firmware update?
usertwgLDE7Itl
Cosmic Ray
Monitors and Memory
Ok, I plugged it to an outlet but the issue still happen.
We are especially worried about the long term durability, if someone could reassure us.
dcasa
Cosmic Ray
Monitors and Memory
Update: fix here
@usertwgLDE7Itl
If I may ask, where did you purchase the monitor? Do they have a flexible refund/exchange policy? If so, are you still within the return period?
usertwgLDE7Itl
Cosmic Ray
Monitors and Memory
I bought it on order in an electronic shop. I'm still in the return period but the monitor has a 2 years warranty.
dcasa
Cosmic Ray
Monitors and Memory
Update: fix here
@usertwgLDE7Itl
I'm also within the return period, but here in Canada the warranty is just 1 year.
I really like this monitor but at the same time, I'm very concerned about its reliability. Unfortunately, Amazon.ca no longer carries it so I'm not sure if an exchange will be possible so I'm leaning towards returning it for a refund.
usertwgLDE7Itl
Cosmic Ray
Monitors and Memory
The problem is the unknown source of the issue that seems to be widespread. Maybe the monitor can work 100 years like this or not. I hope samsung will investigate this.
SamsungSteph
Monitors and Memory
@dcasa Unfortunately there is not a Global Support team in the same way that you see support teams for each individual country. Samsung as a whole is indeed a global company, but each Country is it's own entity and handles it's own cases. Samsung US only handles US devices, Samsung UK only handles UK devices and so-on. The mods here are based for US support, so we are happy to help with US devices. If the device was purchased outside of the US though, you will have to reach out to the support team in your area for assistance. I truly apologize for any inconveniences this may cause.
dcasa
Cosmic Ray
Monitors and Memory
Update: fix here
@SamsungSteph
Ok, I understand, thanks for clarifying.
userVLVET502bN
Monitors and Memory
Hi
I am from France and i have exactly the same problem
I have bought this unit the 10 december 2018 at Boulanger Store
Here my post on France samsung community with picture of problem
https://eu.community.samsung.com/t5/Autres/Ecran-C49HG90-PC-image-hachur%C3%A9e-lors-de-l-allumage-d...
useruMfHze6DSH
Monitors and Memory
Same problem here in the UK, guess it's going back and I'll wait for the new 1440p model
