Notification side power button settings Galaxy A14
(Topic created: 11-07-2023 02:27 PM)
Jennapher
A Series & Other Mobile
If anyone can help, just got this phone about
2 weeks ago, and it's drivin' me nuts. So I set my notifications to pull down when I swipe the side power button, huge mistake and for the life of me, I can't find that settin' 🙏🙏please can anyone help🙏🙏
PAHelper
Sun
Settings, advanced features, side key
PAHelper
Sun
Jennapher
Omg thank thank thank...I literally went there a 100 times yet is wss turned off, so didn't think that was it...oh how I feel dumb right now 😅
dieguezwong
Cosmic Ray
Go to the "Settings" app on your phone. then scroll down and tap on "Sound & notification" or "Sound & vibration" (the exact wording may vary depending on your device).Look for an option called "Notification reminder," "Notification key," or "Power button options." Tap on it.In this section, you should find the setting related to the notifications when swiping the side power button. It might be called "Press power button for notifications" or something similar. Disable this option.
Jennapher
Thank you, PACritic hit the nail on the head 😃
Gladyxxx
Hello people please 🙏 get you tell me about in this cell Galaxy A14 Screshot
