VOLUME INCREASE PROBLEM LED 4k65inch
(Topic created: 03-14-2024 06:58 PM)
Lookfast9
Projectors & Other TVs
Last week with new Samsung led update
now I can’t volume up quickly now it’s going by 1+
for exmp. Before I press and hold volume up button it’s rapidly goes to 90 or 100
now I have press and hold volume plus button it’s increase very slowly how do I change this setting or go back to previous update
JBTechfanatic
Black Hole
You should be able to fix this by pressing **Settings**, go to **General** and **Privacy**, then go to **Accessibility**. Scroll down to **Remote Button Repeat** and adjust.20240408_091430_1000006519_1712592872.jpg
1 Reply
JBTechfanatic
Black Hole
