Forgot Password for Tablet E, Cannot Power Off, and Power/Volume Up doesn't help
(Topic created: 01-28-2024 12:33 AM)
user00nk49H8Ys
Tablets
I found an old tablet that a relative gave me in a drawer somewhere, but no one seems to remember the password. Since no one knew it was there, it wasn't logged into Samsung or Google retrieval. I can't get the device to power off, and all the power/volume up combination does is restart the device.What can I do?
bill-e
Cosmic Samsung Care Ambassador
Tablets
If your device is registered with Samsung on Samsung.com you can reset the password on findmymobile.samsung.com
Factory Resetting the tablet will not work because at setup you will be prompted for the password.
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Z Fold 8 Ultra 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
Tidbitty
Black Hole
Tablets
Hold power down until it shuts off. Should take like 10-15 seconds.
user00nk49H8Ys
Tablets
First thing I tried. It turns off the screen. I left the button held for 30 seconds just to be sure.
Power and volume down restarts.
Powe/volume down/home brings you to the custom os screen.
bill-e
Tablets
Bill
