- Mute
01-05-2024 02:15 PM in
4K, 8K and Other TVsI got a new CU8000 over the holidays so far loving the upgrade (my old TV was a 12yr Samsung LCD) I have noticed that if someone rings my Ring Doorbell, I will automatically see who is at the door, and listen to them, but after the connection is dropped to the RING I have no audio o the TV, I have to disconnect the power to the TV in order to fix it. has anyone encountered this issue?
Solved! Go to Solution.
- Mute
02-09-2024 05:18 PM in
4K, 8K and Other TVsWe have the same issue but we hit the microphone button on the remote and it puts the audio back.
- Mute
01-23-2024 02:22 PM in
4K, 8K and Other TVsI have same problem and searching for a solution. Turning off and on did not help.
- Mute
- Mute
03-15-2024 04:44 PM in
4K, 8K and Other TVsThat worked! Now the question is why does this annoying glitch happen! Cmon Samsung say something!
