userBtOcyQNsNx
- Mute
01-09-2023 08:16 PM in
4K, 8K and Other TVsThis tv started experiencing horrible screen judder after a few years. Based on the reviews on Amazon.com this is a common problem with this model. How can this be fixed? It's ridiculous that a $1K+ tv no longer works.
Opens in new window
PDF Download
Word Download
Excel Download
PowerPoint Download
Document Download
Solved! Go to Solution.
Diaboyos
Honored Contributor
- Mute
01-10-2023 12:42 AM in
You may call or text START to 1-800-726-7864 to contact Samsung. Although if the TV is no longer under warranty the cost to repair or replace it will be up to you.
Chris7770
- Mute
01-09-2023 08:31 PM (Last edited 01-09-2023 08:32 PM ) in
It maybe Usage or software update or technology to use to make the TV
Diaboyos
Honored Contributor
- Mute
