- Mute
06-08-2017
07:46 PM
(Last edited
08-24-2023
05:34 PM
by
SamsungCaleb
) in
TV was working fine yesterday I turn it on today and I had an issue with the volume not working on my Samsung remote nor on my Directv remote. So me being the guy I am I tried to figure it out on my own. Googled all possible answers, factory reset my TV. After no positive results I contacted Samsung through Live Chat. We went through the unplug TV for 60 seconds process and that didnt work. He then had me remove my batteries from my Samsung remote and hold the power button for 40-50 seconds then reinstall batteries and that seemed to work for both my TV remote and my Directv remote and I just did that process with my TV remote and it's been going strong for hours already....Hope this helps
Solved! Go to Solution.
- Tags:
- 4k
- Mute
12-31-2020 05:20 PM (Last edited 12-31-2020 05:20 PM ) in
4K, 8K and Other TVsDid ressetting smart hub work for you long term?
- Mute
01-29-2021 04:01 PM in
4K, 8K and Other TVsYou're out of internal hard drive space. Plug In an external usb, reset smart hub, factory reset, reinstall apps.
Seems when the default partition is full it wigs out. Too bad a billion dollar company can't figure this out.
- Mute
01-15-2021 08:08 AM in
4K, 8K and Other TVsYou are correct. None of the steps mentioned in the other comments worked. They may work temporarily, but the only solution that finally worked was to reset Smarthub. You MUST reset Smarthub.
However, when you reset Smarthub, you must log into your Samsung account and then add back all of your apps on the TV. Then, you have to log into each app individually (Netflix, Amazon, Hulu, etc.) before you can use each one. So be sure that you have all of your passwords.
Thank you very much for your post. Otherwise, I may have gone out and purchased a new TV. My Samsung is not even 3 years old and works perfectly.
One other comment: I attempted to contact Samsung support through the TV support feature. You can request a call back by using the support menu on the TV. I waited 2 days for them to contact me. When I finally received a call back from them, it was a recording advising me that their office was closed, and that I should request support on-line via chat. What a disappointment.
- Mute
01-15-2021 08:30 AM in
@userxXX6ApJRho wrote:You are correct. None of the steps mentioned in the other comments worked. They may work temporarily, but the only solution that finally worked was to reset Smarthub. You MUST reset Smarthub.
Were you having issues with controlling volume for a new soundbar or just the tv volume? Sorry, getting confused what issues people are talking about.
- Mute
01-30-2021 08:22 AM in
4K, 8K and Other TVsNot for me.
- Mute
02-03-2020 01:32 AM in
4K, 8K and Other TVsHi there,
First time ever using a discussion group but I too have had recent trouble with my remote volume not working on my 2017 samsung tv. Only began couple of weeks ago and couldnt use remote for volume control. Done everything I could find to sort it but to mo avail. Every time I turned tv on, same problem! I thought maybe it was the samsung remote that had given up as dog chewed it, but that was 18 months ago and all other buttons on it worked fine. Purchased a universal remote, recommended for any samsung tv. Seemed to have paired to tv ok but alas the problem has not! Please can you help as it seems that it is an issue for a lot of people and is only with the volume. I now cannot use my universal remote with my smart tv to add any other devices either as it tells me I have to use the smart remote to do so. No good as I threw it away as I was sure that was faulty and the cause of the problem. Not going to pay to get another smart remote if this is not going to solve the issue.
@Anonymous wrote:Thanks for the update Chrisv909, be sure to post in the larger thread regarding this: https://us.community.samsung.com/t5/TVs/Remote-Control-volume-isn-t-working-on-my-TV-UN48JU6500/td-p/1892
- Mute
10-17-2017 09:16 PM (Last edited 10-19-2017 06:02 AM ) in
4K, 8K and Other TVsDidn’t work for me.
Got it a call from a tech. To solve my issue we took the remote and held it about a 10” from the bottom right side of the screen and held the “back” arrow buttons and “pause/play” at the same time until the tv said it was connecting remote.
Hope this his works for others.
- Mute
01-20-2018 05:56 PM (Last edited 01-20-2018 06:02 PM ) in
4K, 8K and Other TVsAfter 5 hrs of screwing with this , a whopping headache and a long phone call with Direct TV I still had no volume control . I tried the battery removal and hold the power button advice to no avail BUT Your fix worked like a charm!!!! Fixed in seconds and both remotes are now working my volume! I saved this chat just in case it happens again. I cannot thank you enough for sharing what worked for you! You saved me another hour on the phone with Samsung .
- Mute
01-20-2018 06:04 PM (Last edited 01-20-2018 06:08 PM ) in
4K, 8K and Other TVsJust to clarify , holding in the back button and the pause button on the Samsung remote while putting remote 10” away from the right corner of the tv is what finally worked.
- Mute
01-28-2018 10:27 AM in
4K, 8K and Other TVsshould the tv be off when you try this? also which "back" button there are two "left" facing arrows
