Problem with SD card
(Topic created: a week ago)
AshleySuzann
A Series & Other Mobile
I have a Samsung Galaxy A71, had this phone for almost 2 years, have had no issues with this phone til now. Anyways, my phone for some reason isnt picking up my SD card i have in my phone, i have taken it out put it back in. I have reset my phone, and still nothing. Any advice would be awesome.
Thanks
LongHiker
Galactic Samsung Care Ambassador
@AshleySuzann SD cards do fail. Have you tried reading your SD card in another device?
kimberleigh
Comet
Also, before you take out the SD card, you need to go into your storage settings and unmount the sd card. If you dont, it corrupts the card and won't be readable.
3Fees
Red Giant
Format the card and then chuse portable or internal storage when prompted.
Cheers
3Fees
HenryWolbeck
Cosmic Ray
Did you try the one that you got with your phone?
