How to keep mobile hotspot always on and connected
(Topic created: 12-10-2024 02:58 AM)
bigpaul09
Fold & Flip Phones
Hi, I am looking for a way to keep the mobile hotspot connected and always turned on.  Can you please help me 🙂
mermaidcaviar
Supernova
Fold & Flip Phones
This is under the Hotspot advanced settings on my A54, Maybe your phone has similar settings. Automatic turn off never. 1733837903022.jpg
mermaidcaviar
Supernova
Fold & Flip Phones
LongHiker
Galactic Samsung Care Ambassador
Fold & Flip Phones
This can also be a carrier limitation.
realaud
Honored Contributor
Fold & Flip Phones
Why would you want that?  It's my  understanding that as long as something is connected to it, it will stay on.  Why have it on if nothing is connected? Seems like a battery sucker to me. However, as @mermaidcaviar illustrated, you can set it to never time out.
Please mark any response that helped you as your solution.
Hotfairy871
Cosmic Ray
Fold & Flip Phones
For Android:
1. **Open Settings**: Go to your phone's Settings app.
2. **Network & Internet**: Tap on "Network & Internet."
3. **Hotspot & Tethering**: Select "Hotspot & Tethering."
4. **Mobile Hotspot**: Tap on "Mobile Hotspot."
5. **Advanced Settings**: Look for "Advanced Settings" or similar options.
6. **Turn Off Automatic Turn Off**: Disable the option that says "Turn off hotspot automatically when no devices are connected."Additional Tips:
- **Keep Your Phone Charged**: Since keeping the hotspot on can drain your battery, make sure your phone is plugged in or fully charged.
- **Check Carrier Settings**: Some carriers might have restrictions or settings that affect hotspot functionality. Contact your carrier for more information.
Would you like more detailed instructions for your specific phone model?
davidmondy
Fold & Flip Phones
Hi. I would like detailed instructions for the S24 Ultra if you could provide please- I do not find these exact options on mine. Thanks!
Hotfairy871
Cosmic Ray
Fold & Flip Phones
I understand! Here are detailed instructions for accessing the user manual for your Samsung Galaxy S24 Ultra:
1. **Open the Settings App**: On your Galaxy S24 Ultra, open the "Settings" app from the home screen or app drawer.
2. **Scroll Down**: Scroll down and look for a section named "User Manual," "Help," or "Tips and User Guide." The exact name may vary depending on your model and carrier.
3. **Select User Manual**: Tap on "User Manual" or "User Guide." This will open the user manual in your internet browser.
4. **Explore the Manual**: You can browse through the manual to find specific information about your device. Use the search bar if you need to find something specific.
Alternatively, you can access the user manual online:
1. **Visit Samsung's Support Website**: Go to the Samsung support website [here](https://www.samsung.com/us/support/answer/ANS10001611/).
2. **Select Your Device**: Choose "Galaxy S24 Ultra" from the list of devices.
3. **Download the Manual**: You can view the manual online or download it as a PDF for offline access.
Would you like help with anything specific in the manual?
