Buds 2 Pro Labs - Edge Tap Volume Control
(Topic created: 07-28-2024 03:10 PM)
Trigger225
Galaxy Buds
The new system to double tap the edge to control the volume is a good start, but could use a little bit of refinement. Right now, it takes a pretty hard double tap to reliably trigger the volume control; harder than I find comfortable. When it does trigger, the volume goes a little too far up or down each step.
I suggest adding a new pair of settings to control edge tap sensitivity and how much the volume changes each step. These would give users a little more control over this feature to tune to their liking.
1 Reply
DrSeuss
Cosmic Ray
Galaxy Buds
I have the same issue with mine. There a very small sweet spot and it's often difficult to get it just right. I hope they make this touch spot either more sensitive or larger.
