OrganicTimmy
Halo
- Mute
09-25-2024 08:43 PM in
Galaxy Buds
I am not sure if anyone is experiencing this issue, or this "feature". The sound quality significantly reduce when on Off mode, but when turn on either Ambient Sound, Adaptive, or Active Noise Cancelation, the sound quality significantly improves. It is much fuller, immersive and more bassy as compared to Off mode. I am not sure if this is a "feature" or a bug as I remember Galaxy Buds2 Pro didnt have this drastic of a change.
thethrashers89
Cosmic Ray
- Mute
09-26-2024 07:48 AM in
Galaxy Buds
On my s23 Ultra, ive noticed bad audio quality all around. before updating, the sound was loud and clear and punchy.
BeastMode504
- Mute
10-14-2024 03:59 PM in
Galaxy Buds
I'm having the same issue as you and even the bass drop out a lot when I increase the volume....it's crazy.
BeastMode504
- Mute
Sunday in
Galaxy Buds
Do anyone have sound quality issues when selecting different modes? In ambient or adaptive mode, they sound good but when I turn off those features, my buds 3 pro sounds horrible
Any had this happened to them?
userXMs7STHsEh
- Mute
10-18-2024 01:09 AM in
Galaxy BudsBeen having the same issue here. I thought the update for the buds 3 pro would fix the bug, but the issue still persists, unfortunately. Hopefully it can get fixed soon
