Edge panels missing after reset
(Topic created: 06-26-2023 12:09 PM)
userciOoVWuFk9
Galaxy Note Phones
Good Afternoon,
I have a note 10 +.
My phone wasn't responding to touch today and when it did the screens were slow loading. I went to device care and everything was fine so I did diagnostic checks and all was normal. One time I got an error message that the IU wasn't responding so I checked to see if my software was updated and it was. Lastly, I ran a check on apps through Lookout because I thought I might have a virus. After I couldn't find the problem I called T-Mobile tech support. The tech told me to reset my phone. He assured me that I wouldn't lose anything. Well when my phone restarted I had to enable my edge panel again. To my surprise I only have one panel now. Previously I had three. I've gone to edit and it only shows apps I can add it no longer takes me to the additional panels. I especially need my bookmarks that had several locked pages for my business. Ive looked in the Help manual and I can't determine how to add additional panels. HELP. Also what do you guys do when you think your phone maybe hacked? I was in a public library with Wi-Fi off when I started having problems. Any suggestions will be greatly appreciated.
TipsyTrex
Black Hole
Galaxy Note Phones
Settings>display>edge panels is where you want to go to add back your missing panels
TipsyTrex
Black Hole
Galaxy Note Phones
userciOoVWuFk9
Galaxy Note Phones
OH MY God.... Thank you so much. I went there to enable the handle. 🙄 Never clicked on panels because I thought when I set it up before I added them from the handle. Have you ever had the problem with your phone being buggy?
