HELP!!!!
(Topic created: 2 hours ago)
YoungBoyDR
Cosmic Ray
Galaxy Note Phones
GUYS PLEASE HELP!
I just dropped my phone in the toilet. I got it out as fast as I could, but it's dying. I need help.
Srb79
Comet
Galaxy Note Phones
Most of the phone this days are resistant to water damage. It should go back to normal.
Galaxy Note Phones
Do you have a fan?
You can use it to try and dry it out, do not use any heat!
Ekamek
Neutron Star
Galaxy Note Phones
Some say covering it with dry, uncooked rice helps. I have not tried it to confirm.
I would power it off and not try to charge it until it's fully dried.
GaryB82
Galactic Samsung Care Ambassador
Galaxy Note Phones
The first thing you should have done is power it off.
If you've found my post to be helpful, Please like my Comments โœ“โœ“โœ“.
If my response resolved your issue, please press the Like and โœ“โœ“โœ“ to Accept as Solution button.
becksiiana
Halo
Galaxy Note Phones
What model phone? Most phones water resistant and can stay under water up to 20-30 minutes and still works perfectly.. power off and leave it a few minutes then u will be fine
