Note20Ultra ~ Battery
(Topic created: Saturday)
Philscbx
Galaxy
Galaxy Note Phones
On my older Samsung phones, I always had notification alert for low battery.
I've exhausted all attempts to find in settings for low battery alert.
Even just tried Samsung support AI chat, and they assume I have option, but it's just not there.
So in the end, battery has died complete to zero a couple times now, and typically bad timing.
Thanks for input if possible.
Maybe there's a 3rd party App, that I just thought of.now to seek out.
Cheers
GaryB82
Galactic Samsung Care Ambassador
Galaxy Note Phones
On newer models, you can create a routine that notifies you when your battery is running low. However, I'm not sure if the Note 20 has the Modes and Routines feature in its settings.
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
Nittany
Cosmic Ray
Galaxy Note Phones
I dont know about that because Note20 is only running One UI 5.1 to where im running One UI 8.0
nullandvoid
Comet
Galaxy Note Phones
Modes and routine is available on my spare device which is only running OneUI5.1 so it should be available on the Note 20.
Nittany
Cosmic Ray
Galaxy Note Phones
I know i made that routine ill send a screenshot
Nittany
Cosmic Ray
Galaxy Note Phones
nullandvoid
Comet
Galaxy Note Phones
This is mine on my 5.1 device.
nullandvoid
Comet
Galaxy Note Phones
With or without a notification, how do you not look at your phone and see your battery is below a certain level? You usually get notified when the battery gets to about 12% - perhaps you missed the warning? @GaryB82 is correct, you can make a routine to notify you when your battery gets below whatever level you set. You can have the notifican read aloud and you can add a parameter to put your phone on power save. You can also carry a power bank with you.
Nittany
Cosmic Ray
Galaxy Note Phones
Don't ask what One UI im on
nullandvoid
Comet
Galaxy Note Phones
You already said you were on 8.0
