Edge panel tools removed
(Topic created: 12-20-2024 08:12 PM)
plissken1984
Galaxy S Phones
Anyone know if its bugged ? Compass, ruler etc
BrĆ¼ZZi
Supernova
Galaxy S Phones
I still have the option - S24U
ā€ƒ
plissken1984
Galaxy S Phones
I have the 7.0 update 2 and I dont see it anywhere
BrĆ¼ZZi
Supernova
Galaxy S Phones
EDIT:
Since you have UI 7 Beta, you should post questions / report bugs at the UI 7 Beta Forum:
https://us.community.samsung.com/t5/S24-S24-S24-Ultra/ct-p/us-bp-stwentyfour?page=1&tab=recent_topic...
Did you already have "Tools" installed on your phone and it disappeared with the UI 7 Beta? It shouldn't.
BrĆ¼ZZi
Supernova
Galaxy S Phones
I have the S24U / Unlocked but decided not to get UI 7 Beta. Do you know if its a bug?
EDIT: You just found out.
It could be a bug.
Tokas
Halo
Galaxy S Phones
It's not a bug. They planned to remove it on UI 7. There's an article about it, unfortunately can't find it. If I do, I'll post on here.
Iamchaos13
Comet
Galaxy S Phones
No. It's not being removed you won't be able to get the panels on the store anymore, but if you have them now, you'll keep them.
MrGhoul
Red Giant
Galaxy S Phones
Here is the Samsung bulletin on the edge panels.Screenshot - oo_1000000978_1733039288.jpg
plissken1984
Galaxy S Phones
It's odd that I had it set as my 3rd panel, noticed it wasn't there so went to search for it on the edit screen , not there . Just checked my apps on galaxy store, its not there either
Lolabear
Galaxy S Phones
Anyone know how to get rid of the bottom panel on the s24 fe I removed the side panel but was unable to locate how to remove the bottom one?
