S20 ultra severe battery drain
(Topic created: 08-23-2024 02:17 PM)
SMASNUG100
Halo
Galaxy S Phones
Battery drain caused by messages and play services, what do I do??
1 Reply
Galaxy S Phones
Likely due to older battery that degrades over time. Try to install good gaudrians from the galaxy store and they have some options. Also reduce screen resolution to 1080p and 6hz. Or if nothing work you may have to replace your battery.
