Alarming battery drain on S22
(Topic created: 02-06-2024 02:22 PM)
Raptorxzero
Galaxy S22
Bought this S22 about a year and a half ago and have been using fast charging ever since then, lately I have been noticing an alarming decrease in battery life. And here is an example from today, where I really didn't use my phone at all at work. And when I come home, it only had 14% battery left. Checking my app usage, nothing really showed up, but something is draining the battery fast. Is there any way to fix / help this or is the battery just wearing out?
Samsung_Moderator
Galaxy S22
Hello! I can absolutely understand needing your battery to not be drained so fast!
I found these troubleshooting steps (https://www.samsung.com/us/support/troubleshoot/TSG10001538/)
Check out this link with best practices after an update: https://us.community.samsung.com/t5/Tips-Tricks/Best-Practices-After-an-Update/ba-p/3200871
If you are still having issues after trying this troubleshooting I would suggest having the device looked at by a certified technician.
You can use the following link to find a list of service centers in the U.S. that can do the repair: http://www.samsung.com/us/support/service/location or by calling customer support at 1-800-726-7864. For service outside of the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html  I do apologize for any inconvenience.
kushi
Galaxy S22
Samsung_Moderator
Galaxy S22
