Expert Raw Shutter Speed sets to manual 1/150
(Topic created: 11-24-2022 11:46 AM)
JonK14
Halo
Galaxy S22
Almost every time I use it the shutter speed sets to manual 1/150
Tom6068
Supernova
Galaxy S22
Try clearing the app's cache and data. It will be reset to default settings but that may solve the problem. You can also create a custom setup within the app too.
NotHughMahn
Galaxy
Galaxy S22
You can manually change it, or set it to auto by tapping the MANUAL icon.
JonK14
Halo
Galaxy S22
I do but it's just annoying that it goes back to some random number in manual mode EVERY TIME I use expert raw
Tom6068
Supernova
Galaxy S22
