- Mute
ā05-15-2024 11:11 PM (Last edited ā05-15-2024 11:13 PM ) in
Galaxy S24Cant hear audio clearly during calls using my type c headsets. (I hear robotic voice).
Issue exists for all type of calls. Phone, whatsapp telegram.
Audio is fine while listening to media. I have tried the same headphones with other phones and even my old s23. Its working fine for both media and calls on all other devices so clearly no issue with my headphones.
- Mute
ā05-16-2024 12:04 AM in
Galaxy S24- Mark as New
- Mute
ā05-16-2024 08:38 AM in
Galaxy S24@buggaboo44 Just like with every device, you would need to put your headset into pairing mode, how this is done may require you to consult the manual. Then you would search for a new Bluetooth device from your phone, once they see each other, you may need to type in a pairing code.
Bring down the notification shade | Long press the Bluetooth icon | Select your headphones from the Available Devices section
- Mute
ā05-16-2024 10:12 AM in
Galaxy S24Can some one with s24 (exynos) check if this is a software issue please š
- Mute
Friday in
Galaxy S24
What Samsung device are you using? I use a Samsung A55 and also experience the same case. Or is it because Exynos doesn't support it? I also tried it on another Exynos device. I tried it on Samsung A53 and A24 devices, the same thing happened.
![](/skins/images/66CEF402179CAB9D909291AF7FAB7B95/responsive_peak/images/icon_anonymous_message.png)
