- Mute
ā01-24-2024
03:01 PM
(Last edited
ā02-27-2024
10:01 AM
by
SamsungJustin
) in
Hi All
I've just got my S24+ today to upgrade my trusty but ageing S10+ having not strayed from Samsung for almost 10 years. Naturally I was hoping it would be an upgrade in all departments but although on the whole it is, there's several annoying and unexpected downgrades that are making me seriously question whether it's actually worth spending quite a bit of money to change.
Firstly, the screen although pin sharp is really washed out. Even in vivid mode the colours are dull and the blacks are significantly more grey than the S10 screen, and even look washed out when put alongside my wife's budget spec A52! I've played around with brightness and colour tone etc but I can't dial it out, and my cousin who's got an S24 Ultra said exactly the same when comparing it against the S22 it's replacing.
Then there's some bizarre features missing from OneUI 6.1, the ones I've noticed so far are specifically in the Always On Display settings. I use AOD to display as a bedside clock, with my S10 and also in OneUI 6.0 / Android 14 on the A52 you can rotate the AOD to landscape orientation and control the brightness, you could even do the latter from the AOD lock screen by tapping twice on the clock to access the brightness slider. In OneUI 6.1 unless I'm missing something it seems all that functionality is missing, the brightness of the AOD is linked to the main screen brightness setting which is far too bright for overnight use, and you can't set it to landscape mode which I'd prefer when on it's horizontal night stand next to the bed. Why this functionality would be omitted I have no idea, but it's really annoying! Please someone enlighten me to some hidden menu somewhere that fixes all these issues?! š
Solved! Go to Solution.
- Mute
ā03-20-2024 06:37 AM in
Galaxy S24- Mark as New
- Mute
ā03-22-2024 09:29 AM in
- Mute
ā03-31-2024 06:20 AM in
- Mute
ā01-31-2024 12:14 PM in
- Mute
ā01-31-2024 01:44 PM (Last edited ā01-31-2024 01:54 PM ) in
Galaxy S24I waited till the last day to order my phone; for this reason, mine's not coming until the 21st. And then I'll have two weeks to check it out. I figured by that time, if they're going to fix any of these significant problems that I see, it should be done by then, or I'm just going to send it back without even opening it.
- Mute
ā01-31-2024 11:27 PM in
- Mute
ā02-01-2024 05:46 AM in
- Mute
ā02-01-2024 06:28 AM (Last edited ā02-01-2024 06:28 AM ) in
- Mute
ā02-01-2024 08:45 AM in
Galaxy S24Any idea how this could have happened to a brand new device though? Brightness was never on max, nor brought out into a particularly sunny environment. Screen has barely been on a few hours total. Unless it was defective from the factory..
- Mute
ā02-01-2024 08:49 AM (Last edited ā02-01-2024 08:49 AM ) in
Galaxy S24
