Edge Panel won't extend
(Topic created: a month ago)
UwUooter
Galaxy S24
All of a sudden my edge pannel won't fully extend from one side to another? Is there a setting for this?
LongHiker
Galactic Samsung Care Ambassador
Galaxy S24
@UwUooter I've never seen the Edge panel go from one side of the screen to another.
realaud
Honored Contributor
Galaxy S24
Isn't that why they are called *edge* panels? Because they stay on the edge.
kimberleigh
Comet
Galaxy S24
You talking side to side or up and down ??? Mine goes from top to bottom but not across on my screen.
Slimside
Galaxy S24
Yes, you can do that. Just go into the settings and you can change the color or make it bigger or whatever you want or move it from one side to the other.
LongHiker
Galaxy S24
You are talking about the handle for the Edge panel. Not the Edge panel itself.
Galaxy S24
What kind of device is that? Because the Edge Panel is too too short. I don't think you mean side to side? You mean why isn't it extending the full length of the device. I've never seen it look like that before.
HenLuv9
Galaxy S24
My edge panels are no longer enabled what happened
LongHiker
Galaxy S24
@HenLuv9 Go to phone settings -> Display and make sure that Edge panels are enabled.
Also go into phone settings -> Display -> Edge panels -> Handle and set the color, size, and transparency so that the handle is visible.
