S24 Ultra speakers sound Tinny, Low Sound, with No Bass
(Topic created: 01-27-2024 09:04 PM)
Hba32701
Cosmic Ray
Galaxy S24
Speakers lack bass compared to my s23ultra. I'd expect every aspect of a new phone to be better, if not the same as the previous generation. The s23ultra speakers sound fuller and much more balanced than the tinny sound coming out of the s24ultra. Maybe calibrate the speakers better?
Galaxy S24
Same issue for me, brother. Samsung needs to push an update because the speakers so far sound garbage and very low
JG94
Halo
Galaxy S24
Are they better that the s23 ultra's?
Kett
Cosmic Ray
Galaxy S24
Yes, more clear
JG94
Halo
Galaxy S24
What about bass?
Kett
Cosmic Ray
Galaxy S24
About the same as S23U I think. It's not a big improvement
PAHelper
Comet
Galaxy S24
Sounds about the same but may be a little clearer.
Galaxy S24
My speakers (as well as about 100 others) are really low sounding. idk if a software update will fix it, but it's currently a problem for a lot of people
Sors
Galaxy S24
For my device. I compared it to my s22u and my friend s23u and sound is much louder and more clear with better base specially on top speaker (the bottom one is not good tbh!) but if you compare it with other phones even with samsung's own note 10+ that I had and s21 ultra yes it's not good at all but I don't complain much here as it's better than my s22u.
Anyway there are 2 options to make the sound better. The faster option is by turning on the dolby atoms on the Samsung music app or by using the dolby atom icon on the notification panel, but this option doesn't sound good on all speakers or all type of musics.
The second option is using the "adopt sound" option inside the "sound quality and effects" menu (you could find it with equalizer icon inside the samsung music app). With this option you could get totally different result from each speaker and different devices you use specially Bluetooth devices but you have to tune the sound carefully and manually for each device to get the best sound and with a little play with this option and it's app you could be suprise how much better everything could sound. I hope it can help you solve your problem.
Another important note is not to use the smart switch app for transferring data between your old phone and s24u. I used this option at first and found out my phone got so buggy with everything than when using it with factory reset and manually install everything and manually adjust settings, etc. I suggest you if you use this option and you experience different and unusual bugs with camera app, sound recording quality, screen quality, and wifi, also try factory reset your phone and not use smart switch. By screen quality I don't mean vivid color option as it need software update from Samsung to retune colors like before, I mean weird color or behavior in natural mode compare to your old galaxy phone in natural mode.
Montu1221
Galaxy S24
I have been using Galaxy's S24 Ultra from last 2 weeks. The media speaker sound quality is very bad. It's so low in terms of output that even IQOO and Motorola phone can beat this one. Mic quality is also not that great. You can hear lot of disturbance and increasingly loud background noise while talking or recording songs, videos or during calls. Samsung should fix this issue with there next update.
Thank you!
Ibuddy66
Galaxy
Galaxy S24
Same here. Also the sound for Bluetooth is just as bad. Doesn't matter what I do to fix it. Even using Sound Assistant from Good Lock Labs does nothing to alleviate it at all. It's ridiculous.
- Ibuddy66
