Improve Battery Icon Charging Animation and Other Elements
(Topic created: 6 hours ago)
MatthewReiter
Red Giant
Galaxy S25
Hello, I would like the charging animation for the battery icon to be smoother, I noticed that One UI 7 Beta 4 has a smoother battery icon charging animation compared to the S25 version because the One UI version is newer. When do you think the Galaxy S25 Series will receive an update to match the S24 Series One UI 7 Beta builds? The Beta version also has the smaller battery icon and the S25 version still has the bigger icon Also, add the battery health status feature to all other S25 devices because some have that feature but most don't, which seems region-based instead, like some European models have that feature enabled and most others do not. I really enjoy One UI 7 but it still needs some improvements such as being in sync with the Beta builds, with the S24 being on Beta, they get the newer One UI Home and newer One UI 7 in general. I also want newer status bar icons other than the current battery icon like maybe making the rest of the icons thicker or letting some icons match the new app icons.
1 Reply
Oxford
Neutron Star
Galaxy S25
Is it really that annoying?
