bills25
- Mute
8 hours ago in
Galaxy S25
Hi,
Still having battery drain issue after almost 3 weeks with my new S25.
Last night, at 100%, I took my phone off the charger for 10 hours, and the drain was 10%.. down to 90%.
Then, after 2 hours with the phone basically on, a couple of searches battery dropped to 77%.
My app. usage showed only <3%
Can somebody please help and tell me me if my new phone is a lemon? I have my battery setting at "basic".
jt13890
Cosmic Ray
- Mute
7 hours ago in
Galaxy S25
Search "battery capacity" in settings, then make sure that the mAh level says "typical" next to it. If it doesn't that will explain your problem.
bills25
- Mute
7 hours ago in
Galaxy S25
It says 4000 mAh (typical)
bills25
- Mute
7 hours ago in
Galaxy S25
Down to 70% now. What else could it be?
jt13890
Cosmic Ray
- Mute
7 hours ago in
Galaxy S25
If you checked what app are using the most battery, dowbload ampere. It will measure the speed power is leaving your phone. If you have a giant power draw, eg -2000mA, something is using it up.
bills25
- Mute
7 hours ago in
Galaxy S25
š
bills25
- Mute
7 hours ago in
Galaxy S25
I bought this phone on pre-order. Too new to be acting like this. It's been nothing but a headache
I barely use the **bleep** phone
I want my money back or a brand new one. Customer support has been absolutely awful with only 1 exception
bills25
- Mute
7 hours ago in
Galaxy S25
Thank you. If I spend a lot of money on a phone, I just expect it to work. Is that too much to ask?
jt13890
Cosmic Ray
- Mute
6 hours ago in
Galaxy S25
Not at all!
pampavlamera
- Mute
6 hours ago in
Galaxy S25
My phone is cloned whit a group of 3 peoploo
