S25 Ultra: ultra max brightness is much less bright then my s24 ultra
(Topic created: 01-30-2025 04:39 PM)
packcin
Galaxy S25
My s25 ultra max brightness is much less bright then my s24 ultra
SamsungRei
Honored Contributor
Galaxy S25
Hello, Welcome and thank you for reaching out. We understand you are experiencing a difference in the display colors from previous phones.
Samsung continuously enhances the Galaxy phone experiences based on users' feedback. The Galaxy S25 series display has been tuned for a more comfortable viewing experience. You may notice a difference in the color of the display compared to previous models.
Samsung respects all of users’ various feedback about the color of the display, and additional updates have been performed to enhance customer satisfaction and user’s choices. It provides further customizable options for natural display settings.
Settings > Display > Screen mode > tap Vivid > Advanced settings > adjust the ‘Vividness’ slider bar
If ‘Natural’ is selected in Screen mode, or ‘Eye comfort shield’ or ‘Adaptive color tone’ is enabled in Display settings, you are not able to adjust the ‘Vividness’ option as the ‘Advanced settings’ does not appear on the settings menu. (To use the feature, set 'Vivid' mode and turn off those options.)
Additional feedback can be provided using the Error Report feature in the Members app. You can find the steps here: https://us.community.samsung.com/t5/Tips-Tricks/How-to-Submit-an-Error-Report/ba-p/3001692
1 Reply
SamsungRei
Honored Contributor
Galaxy S25
