Antenna connection adaptor
(Topic created: 04-18-2021 04:53 PM)
userC2upy70jFv
HD and UHD TVs
I am attempting to connect an antenna to a UN65C8000.  The BN39-01154P  adaptor cable is no longer available and my has long been lost.  Can anyone suggest an alternative adaptor or let me know  the type of connector on the HDTV?
Thanks.
Georgia2004
Comet
HD and UHD TVs
Have you search eBay for thar adaptor, you would be surprised what is listed, I just search that part number and it is listed on ebay check it out
1 Reply
Georgia2004
Comet
HD and UHD TVs
