- Mute
12-06-2020 03:20 PM in
Home TheaterSubwoofer connected wireless to soundbar. Solid blue light, but no sound, vibration or anything. Tried everything but no help.
Solved! Go to Solution.
- Mute
06-03-2021 07:28 AM in
Home TheaterHey, give this link a shot: https://www.samsung.com/us/support/troubleshooting/TSG01110401/ If this does not help I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case by case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
- Mute
12-09-2020 05:15 PM in
Home TheaterCan you explain what troubleshooting steps you did? I would love to assist you on this matter.
- Mute
12-22-2020 11:17 PM in
Home TheaterI am facing the same issue. I just bought a q70t sound bar. My tv is a samsung uhd 55inch 8series from 2016.
The soundbar works with no issues. The subwoofer also connects to the soundbar without any issues, the connection light is solid blue... However as op stated no audio out of the subwoofer!! I rest the connection couple of times but no luck.. please help!!
- Mute
12-23-2020 01:35 PM in
Home TheaterDoes this happen if you connect a different device to the soundbar?
- Mute
12-23-2020 04:35 PM in
Home TheaterHaving the same issue on the Q950T soundbar and Q90T TV. The only workaround I have found that works is to power up all the connected devices (TV, soundbar etc. ) then after you see the solid blue light on subwoofer then unplug the subs power and replug the power. This seems to force the resync and reconnects to the soundbar.
For what its worth by rear speakers not having this issue just the sub.
I am yet to try re sync'ing using the (manual) setup instructions to see if that helps with a more permant solution.
- Mute
12-25-2020 04:22 AM in
Home TheaterI have same problem. I have followed guidance from Samsung , updated sound bar software etc to no avail. The soundboard and woofer connect-solid blue ligh5 on subwoofer.
This is very annoying since only purchased one week ago.
Any ideas what to do now?
- Mute
12-26-2020 03:35 PM in
Home Theaterhave you removed the power from the sub and reconnected did that work for you? while annoying its fixing the issue for me.
- Mute
12-27-2020 10:02 PM in
Home TheaterYes- and updated firmware and reset etc
- Mute
12-28-2020 04:29 AM in
Home TheaterI had same problem. However, i have solved.
I had only connected soundbar to power and not the TV. The HDMI cable from soundbar i originbally connected went to SKY Q box. I hadnot used eARC HDMI cable connection from soundbar to TV.
I now have a deep base sound emanting from subwoofer- simple mistake on my part.
- Mute
04-28-2021 08:23 AM in
Home TheaterHi, I'm using a QLED Q90T 55" tv and a Q70T soundbar. The connection is via eARC. I've even purchased a brand new HDMI lead that supports eARC.
Solid blue light on subwoofer.
Updated firmware in tv and soundbar.
Tried manual reconnection with subwoofer.
Tried the initialisation of the soundbar.
Tried unplugging the subwoofer and plugging back in.
Still no sound from the sub.
Tried external devices ie samsung phone. Still nothing.
Please help.
