Adjusting 4 door flex (non Bespoke) bottom doors
(Topic created: 07-28-2023 11:52 AM)
user3WzfKZCpU0
Kitchen and Family Hub
Hello everyone,
I just got my 4 door flex today & im having trouble trying to figure out how to adjust the bottom doors. Any help would be much appreciated. Thanks in advance!
JBTechfanatic
Black Hole
It's actually very simple what you're going to want is a large wrench or pliers on the two front feet only turn clockwise right side then left side and tell all your doors are aligned and you will be set also in the bag with your manual you will see little plastic c clips you can use these in the bottom hinges of the door to slightly raise or adjust but you really want to adjust the feet mainly
1 Reply
JBTechfanatic
Black Hole
