Bespoke Induction Oven Door Window Cleaning
(Topic created: 12-28-2024 11:10 AM)
OldLadyWho
Kitchen and Family Hub
Has anyone had to clean the INSIDE of one of the oven door windows? I haven't found a link to anything for this particular range NSI6DG9500MTAA. I am assuming it is as simple as removing door, undoing all the screws and pulling things apart to get to the window, but am a little nervous about the whole process.  Any tips would be appreciated!
Edit - I did find a how to on the Samsung site - remove door, use long object wrapped in a cleaning cloth and find the gaps and grooves, use 'tool' to go between windows and clean.  Anyone tried this?
loganwalton
Great advice! Thank you!!
OldLadyWho
Finally tried it. Taped a microfiber cloth to a yardstick. Used Windex on cloth, which probably is against their advi. Saw it can be used on outside front, but no suggestions for inside! No problem seen yet, so am assuming I didn't break anything!
