Best water filter for samsung refrigerator? Advice needed!
(Topic created: Saturday)
clearingskulk
Kitchen and Family Hub
Hey, I need help finding the best water filter for my Samsung refrigerator. There are so many options out there, and I’m not sure which one is actually worth it. I want something that’s reliable, easy to install, and actually improves the water quality. Does anyone have a recommendation or know if the official Samsung filters are better than third-party ones? Thanks!
realaud
Honored Contributor
I have never had a problem in my Samsung refrigerator with a third party filter.  I have been using Waterdrop for years. You can buy them on Amazon.  They are 1/3 the price of a Samsung filter. They fit well, don't leak, and my water is pristine.
frapheight
Stick to the official Samsung filters—they’re made to fit perfectly and actually improve water quality. Third-party ones might be cheaper, but they’re hit or miss with quality and can leak. The Samsung ones are easy to install and worth the price for peace of mind!
realaud
Honored Contributor
Never had a 3rd party filter leak.  When buying 3rd party, you have to look for the official certifications. I've done testing of my water with the Waterdrop filters, and it gets out what it says it does.  Of course, it could also be that my municipal water is just fine without the filters--but I doubt it, judging by the condition of my skin and hair when showering without a shower filter.
